Connecting Rods - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-03-2007, 05:48 PM
Connecting Rods
I have a 4 bolt main 350 74-80. I'm confused about my connecting rods, I bought 40 over pistons and the connecting rods together. But the rods are used and there not numbered. The crank that I'm buying is reconditioned. So my question is, am I gonna have balancing problems, if I stay with the connecting rods that came with the pistons? And if I am, what should I do? And by the way the rods are pressed into the pistons. Thank you very much.
Old 09-03-2007, 05:55 PM
383silverado's Avatar
have it all rebalanced it's like $150- $200
Old 09-03-2007, 06:14 PM
Jmark's Avatar
86 M.C. welcome to the HR forums!
Were the pistons used too?
Were the rods resized before they were installed on the pistons?
Only the main caps need to be numbered, to keep them in proper oreintation (sp?) in the block.
The rods are sometimes numbered so the cap goes back on it's original rod, but as far as where it goes on the crank, it's not important, as long as it's installed the right way.
If someone prior to you grabbed a few rods from here and a few from there and put the package together for you, it could be a vibrating mess. Unless you KNOW FOR SURE that all the rods came from the same engine, i'd have it rebalanced while it's apart.
Old 09-04-2007, 07:33 PM
pistons and rods
I still have the rods and the pistons from the original motor and those are numbered. So I was thinking I would just use those rods with the pistons. Also, my pistons are flat tops (the new ones) but I was wondering if dome pistons would be better for more compression and horsepower. Thanks.
Old 09-04-2007, 09:12 PM
327NUT's Avatar
Forget the domed pistons, old school stuff. Get compression by proper piston pin height, cyl. head combustion chamber and head gasket thickness.
Scat / Pro Line connecting rods, sbc. Rad Ray Engine 3 12-12-2007 08:38 PM
detonation resistance, short or long rods? Old School Nut Engine 34 12-31-2004 12:23 AM
440 mopar connecting rods k-star Engine 2 07-08-2004 07:13 PM
Ford 302 Eagle SIR 5.400 Connecting Rods CREVISTON Engine 11 09-30-2003 09:23 PM
longer connecting rods shagginwagonvic Engine 2 05-16-2002 09:51 PM
