Connecting Rods (movement) - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-06-2009, 10:22 PM
I just put all cylinders in my 454 and on pistons 1&2 there is a slight movement after I torqued the caps down which is of course normal but the others, no movement.
After I put pistons 1,3,5,7 in I made sure the rod slides across the crank journel and push them back so other rod goes in.
The connecting rods and crank have been machined.
Old 06-06-2009, 11:31 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
The rods and their caps should have been marked for position at disassembly. They have to be kept in order- the caps need to be on the same rod they came from, and the caps need to be correctly orientated on the rods.
If in doubt, you need to re-verify the clearances- plastigage will suffice for a quick check to see if there's a problem with the machining or if the bearings are the wrong size. Check the bearing part numbers to be sure they match your application. Check the side clearance between the rods' big ends.
You can try moving the crank fore and aft- like if you were measuring the thrust bearing clearance, and see if that makes a difference.
Old 06-08-2009, 03:47 PM
caps have the numbers
The caps do have the numbers stamped on them and they are lined up with the connecting rods which also have the numbers stamped on them as well.
I will try to see if I can move the crank any to see if I can get some movement.
Is it going to be a major problem if their is no movement at all? I know you don't want a lot of movement.
Old 06-08-2009, 04:25 PM
ericnova72's Avatar
More for Less Racer
Do you have a set of feeler guages to check the side clearance between the rods and crank?
Is the large chamfer on the rod bearing bore in the rod facing toward the radius edge of the rod pin on the crank and not in toward the other rod? Sometimes rod and piston get assembled together backwards from each other or backwards into the block by mistake.
Old 06-08-2009, 05:14 PM
rod movement
Yes I have a set of feeler guages.
If they are backwards, I'm going to be pissed off, lol. I actually had to read that about five times to try to get a visual of what that looks like. I'll try to check for that. I may even try to see if I can find a good picture in a magazine or the internet.
Thanks
Old 06-08-2009, 06:24 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Another quick check, is to see that all of the witness marks that indicate "forward" on the pistons (if so equipped) or the valve reliefs (that you DO have) are all properly orientated, i.e. that none were installed backwards.
If the pistons were installed on the rods wrong, this can still look right, but then the big ends of the incorrectly installed rods will not be installed with the correct orientation.
With the engine upside down on the stand, with the pistons pointing down and towards you as you stand next to the block (doesn't matter which side), the rods that point towards you should have their numbers orientated in such a way that you can read the numbers on the rod big ends. But you should not be able to read the numbers for the rods that are pointing down and away from you. Those numbers should all be seen from the other side of the engine.
The engine's numbered:
Drivers side- 1, 3, 5, 7
Passenger side- 2, 4, 6, 8
Old 06-08-2009, 06:54 PM
mc73DD189,
What I do when I put an engine together is after I install a piston/rod assembly to the crankshaft I turn the crankshaft to be sure it did not "lock" the crank. I kind of figure as you installed your pistons you had to rotate the crankshaft so you could install the next set.
If the crankshaft can be turned by hand and all pistons have their orientation mark pointing to the front of the engine you are good to go. You can try and fit a feeler gauge in-between the connecting rods on any given journal but that will be very small space.
Now if the crankshaft can not be turned by hand then loosen one bearing at a time. Then try to rotate the crankshaft again. Do this until the crankshaft turns. Once you find the trouble figure out what is causing the lock-up.
Good Luck
Scholman
Old 06-08-2009, 07:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Is it locking up or is it just loose in 2 cylinders? Cole
Old 06-11-2009, 04:09 PM
Originally Posted by scholman
mc73DD189,
Good Luck
Scholman
The crank is moving. It turns pretty good. The groove in the pistons are pointing forward. My biggest problem is pistons 1,2 the gap between the rod caps after torqued down I can stick a feeler guage in between them but it reads .008 and according to the book it should read at least .010. The other rod caps, I can't even get a reading because it's a too tight between the two caps.
As for the connecting rods possibly assembled backwards, this I'll check tomorrow and hope things are ok.
I was at a website and saw a picture that may help. If the engine is upside down and I'm facing the front of the engine, the stamped numbers of 2,4,6,8, should be facing to the right and 1,3,5,7 should face to the left.
I'll get it figured out and I have faith in the guys that assembled the connecting rods and pistons.
Thanks for all the help, everyone.
Scat / Pro Line connecting rods, sbc. Rad Ray Engine 3 12-12-2007 08:38 PM
440 mopar connecting rods k-star Engine 2 07-08-2004 07:13 PM
Ford 302 Eagle SIR 5.400 Connecting Rods CREVISTON Engine 11 09-30-2003 09:23 PM
Looking for Ford 390 connecting rods geobarn Engine 3 09-15-2002 04:30 AM
longer connecting rods shagginwagonvic Engine 2 05-16-2002 09:51 PM
