The spring won't cause an oil burning issue but the spring you have does not have nearly the pressure recommended by the cam manufacturer. The result would be valve float, unless that cam lifts out higher than .590. Then you'd have a heck of a coilbind issue which would show up right away as major carnage.
To the best of my recollection, valve springs wont cause oil consumption but if they are weak will cause performance issues, ie valve float. Side loading of the valve through incorrect rocker geometery or using stock rockers on a high lift cam can cause valve guide wear which can contribute to oil consumption. Have you tried running the engine without a pcv, just 2 breather and compare consumption.
The cam lift is around .480 with 1.5 rockers. Could you be more specific about the valve floating issue? Would this affect the performance at only really high revs. like over 5,000 rpms or so or could I indeed have really lousy performance all the way through the RPMs right of the line? thanks,Ronald. |
Insufficient spring pressure will only rear it's ugly head at high rpm. But, the springs you are using should be ok for that cam. Your seat pressure is at max for a hydraulic cam and that cam lift is easy on springs.
I would look at an improper intake gasket seal. Sucking oil up on the underside of the manifold. I've seen it happen many times with aftermkt aluminum heads.. Or possibly a bad valve seal install. |
Steve, Yes I have tried the breathers only without the PCV and after only 30 miles oil was getting out the covers through or around the breathers grommets..so I came back to the PCV...I have a leak down tester and just can't wait to check those cylinders. Ronald. |
Bob covered the spring quetion. You do seem on the right track though with the leakdown test. It' going to run like crap with an oil and gas mixture in the combustion chamber.
Not a lot of places it can be caused by, intake gasket, rings, guides. With the breather issue I'd have to guess rings/ blowby issue. |
| Why spend money on heads? | F-1Rodder | Engine | 8 | 03-07-2008 12:09 AM |
| Wut set of heads for my set up? | Trav | Engine | 2 | 10-15-2003 09:45 PM |
| New heads? or work with mine? | Trav | Engine | 2 | 09-29-2003 06:43 PM |
| Vortec heads and High Valve Lift Question | TurboS10 | Engine | 4 | 03-05-2003 02:16 PM |
| sbc heads | Jared | Engine | 7 | 03-03-2003 07:07 PM |
