-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   consew 206 rb-5 (http://www.hotrodders.com/forum/consew-206-rb-5-a-197216.html)
rodrieguz 04-25-2011 03:28 PM
consew 206 rb-5
I purchased this machine a couple days ago and can't seem to get it to stitchs correctly. (Or in my mind) the loop that's usually found on the bottom of the material that holds the stitches tight is on top???? Is this correct??? the manual I have is very vague in analizing these thread issues.
DanTwoLakes 04-25-2011 03:41 PM
Stitching should be equally tight from the top and from the bottom. If the thread is straight on the bottom, the tension is too tight on the bobbin case, or the top thread tension is too loose. If the thread is straight on the top, the top tension is too tight, or the bobbin tension is too loose.
Look at page 13 of this Singer manual, it is explained very well: CLICK HERE
rodrieguz 04-25-2011 04:50 PM
consew 206 rb-5
Thanks Dan,
right on the money, now if I can just slow this beast down.
bentwings 04-25-2011 08:55 PM
1 3/4" x 3/4 " die cast pulley from Tractor supply is a bolt on.
DanTwoLakes 04-26-2011 04:47 AM
To the sewing machine's motor. You'll probably have to bet a different belt, too.
rodrieguz 04-26-2011 08:54 AM
I'm going to hunt for this pulley today,
what am I doing wong when the needle won't pick up the bobbin thread?
I've rethread both with no luck. I lifted the machine up to look underneath turning the wheel towards me to pick up the bobin thread, the out side of the bobbin case moves but the inside were the bobin is does not move???
Coodeville 04-26-2011 09:37 AM
Is the needle in correctly? Have you ever had a mechanic look at the machine?
rodrieguz 04-26-2011 10:15 AM
just bought the machine, it is fairly new used a couple times by the previous owner. It worked fine before, I sewed two pieces of carpet and was maybe practicing with some scraps and it stopped sewing :confused:
DanTwoLakes 04-26-2011 11:36 AM
Is the top thread on the machine correctly threaded? Do you have the bobbin thread installed correctly? The thread pulls off the bobbin to the left side. If you put it in backward the bobbin thread won't get picked up. You also need to get the bobbin thread under the spring steel tension on the side of the bobbin case. Are you threading the needle from left to right? Does the thread go through the thread guide just above the needle at the bottom of the needle bar?
rodrieguz 04-26-2011 06:29 PM
thanks for all the tips and advice, don't laugh but the belt was off the machine, if that makes any sence. I put it back on and everythig worked ok.
Still trying to get the tentions in sinc.
Thanks again guys
DanTwoLakes 04-27-2011 05:09 AM
The belt was off the machine? Did you change the motor pulley? If so, you really need to tighten the belt or adjust the motor pulley so that it is in a straight line between it and the machine pulley, 'cuz that should never happen.
rodrieguz 04-27-2011 08:13 AM
I think it may have come off when I tilted the machine. The pulley i have is a 3" If I get the 1 3/4" to slow the machine down would I need a different belt?
DanTwoLakes 04-27-2011 08:54 AM
You're going to lose 2" of belt length with a 1 3/4" pulley, so if you don't have 2" of adjustment, you'll need a 2" shorter belt.
