Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - consew 226R
Thread: consew 226R
Old 08-26-2011, 02:31 PM
goradal goradal is offline
One more question!
Thanks again,
One more question, I oiled up the baby following the instructions from the manual. It said to fill the bobbin well with oil so I did. Mind you not completely just the lower right part that has the little indention not to the point of touching the bobbin but you could see the oil. Then a couple of days later I look and it has all run out. Is this normal or should I have not put that much in? Thanks
