-   Interior (http://www.hotrodders.com/forum/interior/)
-   -   Consew 226R-2 (http://www.hotrodders.com/forum/consew-226r-2-a-230477.html)
white72gs455 03-09-2013 10:59 AM
Consew 226R-2
Hi, will the consew 226R-2 work on leather/vinyl upholstery.
I have a lead on one...
What's the difference between a 226R-1 & 226R-2?
DanTwoLakes 03-09-2013 11:20 AM
It's just a newer model than the 226R and R1, and yes, it will sew anything you want as far as a car interior is concerned. There may be slight differences between the models, but they won't be much different. If it's in good shape, and you can buy it for $900 with a table and motor, buy it. My 226R is 50 years old and works like a champ.
white72gs455 03-10-2013 07:07 AM
Thanks!
How about a singer 251-3?
Same questions...
:thumbup:
DanTwoLakes 03-10-2013 08:34 AM
Never heard of that one. If I were you, I'd stick with the Consew 226.
white72gs455 03-10-2013 12:04 PM
1 Attachment(s)
Couple photos...
white72gs455 03-10-2013 12:05 PM
1 Attachment(s)
The singer
white72gs455 03-10-2013 02:12 PM
http://parts.singerco.com/IPsvcManuals/251_CLASS.pdf
This say it is heavy to lightweight.
The only reason I ask is... They are both up for auction, I may get out bid on my 1st choice.
DanTwoLakes 03-10-2013 05:12 PM
Here's the difference between the two: The Consew is newer and has reverse. The Consew has a vertical hook which loads bobbins from the right of the needle. The Singer is older, does not have reverse and has a horizontal hook like a Consew 206, which loads bobbins from the left of the needle. It does have automatic lubrication, but to me that's not any kind of advantage.
Just having reverse is enough to get the Consew over the Singer.
white72gs455 03-10-2013 08:00 PM
Thanks Dan!
I do appreciate your help!
