console - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2005, 12:02 AM
KRD KRD is offline
New Member
console
I want to make a fiberglass center console for my 77 trans am. I was thinking of using styrofoam for my mold, but am worried that the chemicals will eat through it. Will styrofoam work? I went to my local paint shop and he said maybe I sould try duraglass. The reason for the styrofoam is so I can peel it after it has dryed. Any suggestions? Thank you
Old 10-14-2005, 03:36 AM
S10Fan's Avatar
Garage Filler
Last journal entry: I need more time!
I built mine with a wood frame wrapped with fleece material. The fleece was then covered with fiberglass resin and cloth. Be ready for a lot of sanding and be sure to sand it outside. LOL. Mine will be covered with upholstery so it didn't need to be perfectly smooth.
There's one picture in my journal.
Old 10-14-2005, 06:24 AM
KRD KRD is offline
New Member
The reason I did not want to use wood is that it is unnecessary weight.
Old 10-14-2005, 04:57 PM
S10Fan's Avatar
Garage Filler
The wood frame is made from 1"X1" material. The console with fiberglass weighs maybe 5 lbs.
I've seen guys use chicken wire to make needed shapes and then add fiberglass.
96 Blazer Overhead Console Temperature Indication 454impala69 Electrical 13 03-25-2010 11:21 AM
64 Impala SS - Paint prep for center console 64Joker Body - Exterior 4 06-08-2005 06:58 AM
center console instalation helrazr3 Interior 2 03-26-2005 01:59 PM
700r4 Shifter in my 68 firebird console? 68firechicken Transmission - Rearend 4 10-07-2003 09:01 AM
How to make a new center console? Jag Daddy Interior 7 05-14-2003 10:22 AM
