Console shifter - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-12-2003, 11:31 AM
Scuzzy's Avatar
Certified Cruck Lover
Console shifter
I was thinking about putting a new (96-02) s-10 blazer console in my g-body el camino, my question is, will the shifter on the console hook up to a th-350?
Appreciate any help
Old 06-27-2003, 12:04 AM
Scuzzy's Avatar
Don't you all jump in at once now, I can only read so fast
Old 06-27-2003, 02:48 PM
I don't have a clue, but I'd guess a '96 is a cable-operated shifter. Most GM shifters have the detent controlled by a plate in the shifter, and then the cable is attached to the transmission.
I guess what I'm saying is that, if it doesn't just bolt right in, you should be able to make it work without too much trouble, maybe some simple bracketry on the trans. I'd guess the biggest worry would be a too-short cable.
This is all just speculation...
Old 06-28-2003, 10:59 PM
Scuzzy's Avatar
Speculation or no thanks for the reply
Old 06-29-2003, 08:40 AM
kristkustoms's Avatar
First name...............Shawn
If it was me, i would say it isnt worth trying. Plus the indicator on the console for the blazer is more than Likely P R N OD D 2 1 (overdrive transmission). And a 350 isnt overdrive, P R N D 2 1
Old 06-30-2003, 02:27 AM
Scuzzy's Avatar
then what would be a good and relatively simple console swap into a g body el camino ?
Old 06-30-2003, 09:14 AM
Lots of G-body cars came with center consoles.
Cutlass certainly comes to mind as a common one. Regals had them as well.
