constant pressure valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2007, 05:06 AM
Hey guys,
How about some input and oppinions on TCI's new 700r4 constant pressure valve body? Has anyone tried it on for size yet? What about in a driver street rod? I am debating. Need some opinions from someone that has this valve body in use.
As always thanks
Old 12-11-2007, 05:15 AM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by maninacoupe
Hey guys,
As always thanks
been discussed here:
clik here
and
HERE
Old 10-24-2008, 01:12 PM
Tci 700r Valve Body ?
ive been running that in my 700r for about 5 months was great till i broke one of the main drums ...cant remember the name has teeth and a huge C clip some of the teeth busted ...my tranny guy said he had only seen it once before in 25-30 years put that back together and then recently not sure what happened ...either my converter let go and lunched the pump (the pump teeth were the converter engages was shattered)or the pump let go its own...anyway my tranny guy was leary of it (200 psi constant pressure) and that is the 2nd time something busted. its a very positive firm firm shift although i have felt other shift kits just as harsh the question remains is it to much for the tranny to take ? im still running mine if it breaks something again i will be re thinking the situation...the benefit is no burnt clutches etc. but if your busting hard parts ??? ive got mine behind a roughly 400 horse 425 flt pds sm chevy in a 77 nova. dont know what else to say but those are facts... tough call problem is im not sure i wouldnt have busted stuff if it wasnt in there good luck ...adrules12
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 01:10 PM
constant pressure valve body (700r4) Boosted89RS Transmission - Rearend 4 11-05-2007 08:00 PM
700r4 valve body question blacklabzeke Transmission - Rearend 2 03-24-2007 12:24 PM
Cam Help black66 Engine 3 05-12-2003 06:15 PM
AOD throttle valve pressure port mustang66maniac Transmission - Rearend 2 01-08-2003 02:44 PM
