constant pressure valve body (700r4) - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-03-2007, 04:38 PM
tci makes a constant pressure valve body
http://www.tciauto.com/Products/GM/gm_4L60E.asp
would this be good for a car that sees mostly track use with the ocaisional street use.any advantages over using the reg valve body,or a full manual valve body
Old 11-03-2007, 06:04 PM
jakeshoe's Avatar
Go look at the instructions sheet from TCi for that VB. The TV cab;e must still be hooked up and properly adjusted, so I would ask, what's the point?
Sounds like a good way to accelerate wear on the pump.
Old 11-03-2007, 06:39 PM
yeah i did tv cable is used for shift points only.im gonna rebuild one last trans before i spend the money to have one built,so i was just looking at things to help.one of my friends pointed me to a full manaul reverse shift valve body with transbrake that i may give a shot
right now this is what my parts list is looking like
.570 boost valve
jumbo servo kit
beast sun shell
high output 10 vane front pump
29 element sprag
red eagle or Kevlar band (dont know which one yet)
red eagle 3-4 clutch pack
all new steels
low/reverse clutch pack
and possibly the manula.rev/tb valve body
Old 11-03-2007, 07:35 PM
forget my previous post i just found an adapter plate so im deff going to go with a turbo350 with a brake
http://www.speedwaymotors.com/p/3280...to-TH-350.html
Old 11-05-2007, 09:00 PM
70 ElCam's Avatar
Rebel with a Chevy
Cool, you finally found one. Speedway has some cool stuff. I like the converter hub extension. It looks like you would use it in a needle bearing or a bronze bushing to center it in the crank flange. Does it come with spacers for the converter bolts?
Fabricating intake manifold. gemini86 Engine 25 10-02-2009 02:10 PM
700R4 quick diagnosis? Chuck78 Transmission - Rearend 14 12-19-2006 12:43 AM
Cam Help black66 Engine 3 05-12-2003 07:15 PM
AOD Valve Body ?s mustang66maniac Transmission - Rearend 3 03-15-2003 03:12 PM
C4 valve body mhaener Transmission - Rearend 0 12-26-2002 12:01 PM
