Continuous in tank fuel pump problems? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-02-2013, 11:36 PM
I am working on a stock 1973 Vega. The car sat up for ten years before I got it. I removed the gas tank had it boiled out and pressure tested, installed a new fuel pump inside the tank, blew out the gas line with compressed air, rebuilt the carb and the car ran fine for several months. In the last year I have had to remove the gas tank 2 times and replace the fuel pump. Never could see any trash or any other reason why the fuel pump kept going bad. No continuity across the electrical terminals the first 2 times. Now I hear the pump running, but there is no gas coming out of the line near the tank. The longest I let the car set up was 5 days. I have a Holley electric fuel pump that is designed to work outside the tank mounted to the frame. Any reason that I shouldn't use this fuel pump in an attempt to solve the problem for good? I am frustrated with having to remove the tank and replace the fuel pump every few months. Always kept plenty of gas in the tank. Any other suggestions? Thanks
Old 01-03-2013, 09:38 AM
Fuel pump issues
1. The Vega has a Holley two barrel carburator fed by a 3/8 line from gas tank.
2. The tank fuel pump has a sock filter over the suction end of the pump. I installed a new filter when I installed the new pump. When I replaced the pump twice before, I did not see any trash in the filter. I have not taken the gas tank out yet, but I can hear the pump running when I turn the key on.
3. Don't know if wire thickness is heavy enough, but its the wire that GM put in there from the factory. Can't know if pump is connected to a relay straight to battery because all the wiring is concealed, but the pump only comes on when you turn the ignition switch to the on position.
4. I found the stock 73 Vega by accident. My back door neighbor had it. I was planning on restoring the car and selling it for $2700. I have all the body work done and have it ready to paint when the weather warms up to 75 degrees in the spring. I don't want to sell a lemon, so I am trying to fix everything that is wrong with it to make a reliable car. So far this fuel pump issue is the only thing I can't fix permanatly. Thanks for your advise.
Old 01-03-2013, 10:01 AM
Banned
empty out all the gas, then run a few gallons of E85 through it over a period of a week or so. If there is any built up varnish the E85 will dissolve it.
I had to do that to my 78 Bobcat that sat for about 5 years before I bought it and when nothing else would cure it plain old E85 took care of it with no problems.
Old 01-03-2013, 01:06 PM
fuel pump issues
Thanks for all the information. I will give all of this a try and let you know what happens. I live in north alabama a long way from the east coast. Not much to look at now. I have done all the body work but the car is still in primer surfacer. The inside needs to be cleaned up and of course the fuel pump issue has to be solved before I put the car up for sale.
Old 01-03-2013, 02:13 PM
Jake_Dragon's Avatar
Last journal entry: New Carb
I have an 84 Corvette converted to carburetors and have an external pump and have had no issues.
I just removed the pump from the tank and replaced it with a hose and secured it to the bottom of the bracket. I also installed a filter before the pump and one at the end of the hard line.
Been working for a couple of years that way.
Even used the stock electrical connection so it is only hot when the engine is running.
Just make sure its level with or below the bottom of the tank
Old 01-03-2013, 11:36 PM
Here is the electric fuel pump harness and relay kit I use with my Holley electric fuel pump 12-150. You can eliminate voltage problems with this harness. http://www.jegs.com/i/JEGS/555/10564/10002/-1 Be sure to use a 100 micron filter before the pump and a 40 micron filter in front before the carburetor.
Need Help/Advice re In-Tank Fuel Pump!! texastomeh Engine 2 04-08-2012 07:46 AM
in tank fuel pump ndoylend Hotrodding Basics 1 01-17-2012 07:06 AM
Ford Fuel Pump Pressures--In tank pump Bryan59EC Engine 9 06-28-2011 02:56 AM
Use in tank fuel pump or no? BillyJoe General Rodding Tech 7 05-15-2007 08:39 AM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
