Contour sanding pads, reasonably priced - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2007, 02:31 PM
Ripped's Avatar
Last journal entry: First RoadCourse Video
I was surfing the other day and ran across these woodworkers contour sanding pads. They seem reasonably priced, and might work for some of you doing fine detailed areas or complex shapes.
I just thought I'd pass it on, in case someone can use them.
Can I use the same pads? Malibucdl Suspension - Brakes - Steering 5 08-04-2006 07:45 PM
Sanding is the art pepi Body - Exterior 3 08-02-2006 10:40 PM
Wheel clunking and brake squeal skizot Suspension - Brakes - Steering 29 10-09-2004 06:17 AM
Metallic Pads (Brakes) dartshadow1 Suspension - Brakes - Steering 6 05-25-2004 06:18 AM
sanding on contour lines Rubberman2003 Body - Exterior 5 06-30-2003 01:38 AM
