Contradictory Chev Engine coding, 305 or 307? - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-15-2010, 02:15 AM
Hi, I have a 305/307 engine that has two apparently very different numbers, the cast is 14010203 making it a 1980-84 305cid and the engine ID is K0620TCK making it a 1973 307cid, how can this be? Any help here identifying what cid and year engine I have would be great and if it helps the heads are cast 14022801 but I don't know if these were original on the block. Thanks.
Old 01-15-2010, 05:19 AM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Mortec shows 14010203...305...80-85...2 bolt
Old 01-15-2010, 06:13 AM
poncho62's Avatar
Wiki Edits: 5
I would be more inclined to go with the suffix code above the right head.....which in your case shows...
TCK 1973 307 C-20 to 3500
Also, the 1st K in the code shows it is a Canadian engine, which one that ended up in New Zealand would have come from....likely
Old 01-15-2010, 06:21 AM
heads
14022801...80-86...305
Old 01-15-2010, 03:14 PM
Thanks, I guess the only way to verify is pull the head and measure the bore! Cheers
Old 01-15-2010, 03:58 PM
ericnova72's Avatar
More for Less Racer
Casting # on back flange of the block trumps any stamped code on the front pad. The stamped application codes on the front pad below the passenger side head were often "recycled" and reused a few years apart on differnet size or hp engines, and should not be trusted until you have looked at the casting # and block cast date code.
I'm willing to bet $100 you have a 305.
Old 01-15-2010, 07:47 PM
I tend to agree ericnova72, especially considering the heads indicate early 80s as does the casting on engine. Cheers
Knowledge base Dave57210 Hotrodders Site Suggestions and Help 2 12-20-2009 07:06 PM
383 engine tapping and oil burning- weird RowShan Engine 15 10-10-2009 05:07 PM
What is the best combination of carb/man for 305 chev keluju Engine 3 07-16-2007 03:36 PM
engine question chevy 305 425HP Z28 Engine 6 11-10-2006 04:29 PM
Suggestions for my 305 Chevy Express engine? wrmason3 Engine 2 09-14-2002 05:51 AM
