control arm - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2007, 07:18 AM
control arm
Im trying to remove the bushings on the control arms. I have a press just cant seam to get them out.is there a trick to this.Thanks mike
Old 08-26-2007, 07:54 AM
Vortech 4.3's Avatar
jack of all trades
mount them in a vice. take the shafts out. use an air hammer with chissel bit to work them out.
Old 08-26-2007, 09:13 AM
powerrodsmike's Avatar
Wiki Edits: 161
If you want to use a regular "H" frame press, you need to block up the A-arm between the bushings. Otherwise the arm just collapses and puts a bind on the bushing.
Here is a pic from a ford manual showing the blocking setup. Chevy can use the same setup.
Here is a set of blocks for chevy a arms I made out of muffler tubing and some scrap steel., The U shaped blocks go in the channel section of the lowers to keep the end from squeezing the bushing.
The cup shaped things with the plate welded on is what you push the bushing into.
I've made those spreaders out of wood too..
You'll need the spreaders to help install the new bushings as well.
Later, mikey
BE different....ACT normal.
Lower control arm hits Granada rotor on stock Mus II suspension Darkman270 Suspension - Brakes - Steering 8 07-25-2006 01:26 PM
Removing Lower Control Arm Shafts 63SS Transmission - Rearend 0 05-09-2006 07:04 AM
upper control arm 67 C10 wickedwitchinak Suspension - Brakes - Steering 1 12-20-2004 09:47 PM
mustang 2 lower control arm bushings nomaddaddy Suspension - Brakes - Steering 1 02-14-2004 12:28 PM
front end popping maddmaxx Suspension - Brakes - Steering 4 11-15-2003 08:24 PM
