Control Arm Bolts - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2012, 08:49 AM
alrobjr's Avatar
Big Al
Control Arm Bolts
I need to remove and replace the lower control arm bolts on a 1981 monte carlo and I need some instructions before I try to remove anythng can you fellows help me out ? By the way they are the front control arm bolts .
Old 08-23-2012, 06:50 AM
78 Z28 Camaro
Last journal entry: 700r4 still running strong
I guess you mean the bolts that go thru the bushings.You didn't go into any detail as to why they would be a problem.Or you need to know in what order you need to take to get them off? I've done this more than I would of liked to.What's wrong with the bolts?
Old 08-23-2012, 07:04 AM
alrobjr's Avatar
Big Al
They are the bolts that go thru the bushings , I see they are rusted real bad and I need to know if the springs need to be compressed or can I jack the car up and remove them with no problem .
Remove upper control arm - Bolts welded. Chucky5150 Suspension - Brakes - Steering 3 07-25-2012 10:34 PM
79 Trans Am upper control arm bolts.. JKear Suspension - Brakes - Steering 2 12-09-2011 03:19 PM
lower control arm bolts helrazr3 Suspension - Brakes - Steering 3 07-09-2007 07:10 PM
control arm bolts were to get them?? cxpcman Suspension - Brakes - Steering 2 06-04-2006 04:51 PM
control arm bolts price Suspension - Brakes - Steering 2 05-11-2006 12:16 PM
