Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Control Arm bushing replacement
Old 03-14-2005, 06:09 AM
redlightning's Avatar
redlightning redlightning is offline
You can get a large bolt and some washers.Put the bolt through the bushing,place the bushing in the control arm the way it is supposed to go.On the other side get a socket larger than the diameter of the bushing.Get more large washers and a nut.Then tighten the bolt and nut.It should press it in.
