Control Arm Bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-01-2002, 07:57 AM
New Member
Post Control Arm Bushings
What is the easiest way to R&R MustangII upper control arm bushings? Is there a tool to do this job? I've heard an air chisel will work to remove them I have numerious heads for the air chisel and I guess one might work, but before I destroy the control arm I,d like some guidence.
Old 10-01-2002, 03:28 PM
aka Duke of URL
Post
There is a special service tool that will press in/out control arm bushings on or off the car. The kit is about $300.00. Needless to say, you would have to do a lot of friend's cars to make that back.
If you are uncomfortable with an air hammer, just take the arms off and take to machine shop.
Old 10-02-2002, 07:47 AM
New Member
Post
Thanks, a friend is getting this tool for 60% of to add to his home shop.
Papabird
Old 10-04-2002, 06:13 AM
SAE Member; ASE Master Cert
Post
Remember to have the weight of the car on the ground before tightening the control arm bushings. Have seen many cases where the bushings are tightened while the car is jacked up, then when it is on the ground, the bushings are in a bind.
Old 10-04-2002, 07:26 AM
New Member
Post
Does this apply to the press in bushings or just the early style screw in bushings? Oh the air chisel with a mushroom head or point head works to remove them just a bit of wd40 and knock away.
Papabird
