Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - control arm bushings
Old 01-17-2010, 03:09 PM
aosborn's Avatar
aosborn aosborn is offline
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The easiest way I have found to remove factory rubber control arm bushings is to light them on fire with a propane torch and let em' burn. In short order you will be able to get the shaft out and then can easily remove the outer shell. Installing polyurethane bushings is a snap from that point, or installing factory style bushings will require a press. Your local machine shop can usually do it pretty cheap.
Andy
