control arm bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-17-2010, 10:57 AM
is it hard to change out your lower ontrol arm bushings on a 63 impala
Old 01-17-2010, 01:03 PM
Just changed the entire front end bushings, on my 1984 C-10. You need patience, air chisel, impact gun. Not that hard, just take your time. I used an aftermarket polyurethane parts to rebuild my front end. Hope this help's.
Old 01-17-2010, 03:09 PM
aosborn's Avatar
Last wiki edit: Suspension: designs, shapes, sizes Last photo:
Wiki Edits: 7
The easiest way I have found to remove factory rubber control arm bushings is to light them on fire with a propane torch and let em' burn. In short order you will be able to get the shaft out and then can easily remove the outer shell. Installing polyurethane bushings is a snap from that point, or installing factory style bushings will require a press. Your local machine shop can usually do it pretty cheap.
Andy
1972 El Camino Control Arm question jaster Suspension - Brakes - Steering 4 09-11-2007 01:39 PM
control arm mounting problems. leldai73 Suspension - Brakes - Steering 14 08-17-2007 03:13 PM
Upper Control Arm Removal Question HeftyP Suspension - Brakes - Steering 2 07-15-2004 06:46 AM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
Lower control arm bushings. What are the tricks of the trade?? Jim Weeks Suspension - Brakes - Steering 7 05-11-2002 08:08 PM
