Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - control arm bushings
Old 10-30-2003, 07:35 AM
60convert 60convert is offline
if you are carefull you can use a sawzall or a hack saww and cut through the shell and then it will come out easy. when putting the new bushings in make sure you brace it so you don't bend your control arm. also before you put the second one in make sure you have the shaft in place.
