control arm bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-16-2011, 12:38 PM
itsandre's Avatar
Hey All, Been a little while since visiting the site.
Finally got my engine/tranny installed in my 62 Impala. The transision from an inline 6 3sp on the tree to a SBC 350 with TH350 is amazing. Lovin it!!! Runs like a dream and I did it all myself as a first timmer. Not without many moments of frustration and bloody knuckles though.
Now I want to tackle a complete front end rebuild. Ball joints, tie rods, idler arm, control arm bushings.
Can anyone tell me how difficult it is to do the CA bushings. Do I have to remove the arms to install the new bushings. If so, should I while I'm at it replace the original coil springs?
Also looks like the original upper ball joints are rivited in, is this so or am I not seeing it right?
Thanks for any advice............Andre
Old 05-16-2011, 03:16 PM
poncho62's Avatar
Wiki Edits: 5
Yes...the original ball joints will be riveted in....The replacements will come with bolts. Yes, you should remove the control arms to rebuild them......They will have to be pressed in.....Whether you replace the springs is up to you.....and how it sits/rides now.
Ontario Rodders
Old 05-16-2011, 05:22 PM
1ownerT's Avatar
Home School Valedictorian
Last wiki edit: Health and safety in the shop or garage Last photo:
Wiki Edits: 4
Since the car had a six and now has an eight plus if they are original springs, I wouldn't hesitate to replace them since you will have it all disassembled.
Old 05-16-2011, 06:09 PM
poncho62's Avatar
Wiki Edits: 5
The sixes in them were likely as heavy or heavier than a SBC.......but, it would still be a good idea
Ontario Rodders
control arm bushings Ajkracing Suspension - Brakes - Steering 8 09-29-2010 07:18 PM
control arm bushings chevyAL Suspension - Brakes - Steering 2 01-17-2010 03:09 PM
control arm bushings montea Suspension - Brakes - Steering 15 04-22-2007 07:06 PM
Control Arm Bushings 69 chevelle SS Suspension - Brakes - Steering 1 08-10-2003 07:50 PM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
