Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Control Arm Bushings
Old 10-04-2002, 07:13 AM
engineguy engineguy is offline
SAE Member; ASE Master Cert
Post
Remember to have the weight of the car on the ground before tightening the control arm bushings. Have seen many cases where the bushings are tightened while the car is jacked up, then when it is on the ground, the bushings are in a bind.
