Control arm relocation brackets - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-21-2009, 10:00 PM
renfroe453's Avatar
Next weekend I am going to be replacing my stock upper and lower control arms, as well as installing drag bags in the rear coil springs. Since I am going this far, would it be to my advantage to go ahead and add relocation brackets for the lower arms??
If so, is there any particular advantage to the "bolt on" or the "weld in" brackets??
Old 03-22-2009, 05:35 AM
SSedan64's Avatar
I'ts up to you. They're used for suspension tuning to reduce wheel hop etc..
Are you getting adjustable upper control arms? If so you may not need the lower brackets. Always nice to have both tho'.
As for mounting differences there's ease of installation. Weld on may be stronger for strip use.
Old 03-22-2009, 10:27 AM
fast68's Avatar
likes chevy trucks & boobies
or if you want to go back to stock or easier replacement in case you bend or break one then bolt on would be the way to go.
im not sure what ppl use them for though
geometry change, or vehicle height change, etc
hmm
good luck
Old 03-23-2009, 11:01 AM
SSedan64's Avatar
They're used for geometry change or IC/ InstantCenter change. For lower control arms, lowers mounting position. For the uppers they make NoHop bars/brackets which raises mounting position.
replacing control arm and body bushings elcaminodragster Suspension - Brakes - Steering 10 09-01-2008 06:07 PM
Worn control arm mount FiveFeezy Suspension - Brakes - Steering 1 03-17-2007 12:08 AM
Upper Control Arm Removal Question HeftyP Suspension - Brakes - Steering 2 07-15-2004 06:46 AM
Control Arm Bushings clouddancer@attbi.com Suspension - Brakes - Steering 4 10-04-2002 07:26 AM
Lower control arm bushings. What are the tricks of the trade?? Jim Weeks Suspension - Brakes - Steering 7 05-11-2002 08:08 PM
