Hey All, Im running a 355 sbc, approx 400 hp, with a 250hp shot of spray and a turbo 400. The 400 WILL have all good parts including a brake and set up for this application. I need advise on a good converter for some street and weekend use. My motor should go to approx.7200rpm, 55 chevy all steel car. B&M...TCI...there many out there for this setup. Any personal experience on this setup?? THANKS DY
If you are actually going to spray the motor that much the converter will need "anti balloon plates" on it.
Tony
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Hey all, I should of added im running a Eagle 4340 steel crank with Eagle"H" beam rods,202 heads 64cc, Vic Jr., 10.3-1 compression with a 4;56 posi. My cam is comp 540/292 dur. My goal is an occasional shot of 250hp spray, with the solid bottom end. THANKS DY YES ballon plates are a MUST!!
