Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Conversion Bearings?
Old 02-02-2013, 11:32 AM
OneMoreTime's Avatar
OneMoreTime OneMoreTime is offline
Hotrodders.com moderator
Wiki Edits: 3
If you have the specs on the bearing required then you can go to an industrial bearing supplier and see if they can get you a bearing of the correct dimensions. Mcmaster carr catalog shows various shaft diameters and outside dimensions and they are not the only bearing supplier out there..
Sam
Check Timken.com for their catalogs and ther are a bunch of catalogs to choose from so you have some homework to do..
