Conversion to cable clutch linkage
I'm considering using a cable actuated clutch on my current project. The car is a 1962 Olds F-85 wagon, and the Rotohydramatic needs to become a T-5. The stock-style clutch linkage has several problems, including availability, clearance for headers, and most importantly, the Z-bar looks like it will conflict with the steering shaft for my rack and pinion conversion. I originally considered a hydraulic throwout bearing, but these cars are unibody and there is a substantial structural brace welded to the firewall right where the clutch master cylinder wants to be. I could use a reverse pedal with the master cylinder under the dash, but this is undesirable for several reasons, including access and leakage.
I've started to explore the cable clutch mechanisms such as those on late model Mustangs, and more appropriately the kits for converting early model Mustangs. These look like they can easily be adapted to pretty much any car. What are the pros and cons of this arrangement, and I welcome anyone's experience with the conversion. |
now i'm wondering why you asked , if you know all the answers .
you using a 455 or 425 motor ? i did this with the ford cable on a 67 olds . i just welded the arm for cable hook up straight out off clutch pedal where the rod through column went , put the cable straight down against floor pan and exited out where firewall roll to level floor board , in the radius part .will be out of way and behind the carpet . then i took cable and led it back to where linkage hooked up made a bend and directed it back to original clutch fork , no flopping the ball socket from one side to another . but maybe this has gone through your thinker already too . |
The 61-63 F-85s are completely different from the 64-up A-body cars. The early ones are unibody and are much smaller. The engine is the stock aluminum 215. |
I'm sure you've considered a juice throw out. Why was this passed up in favor of the cable set-up?
All I recall about the self-adjusting cable set-up was there were plastic components in the OEM version that I seem to recall not liking high-effort pressure plates. But there are numerous "cures" for this already. And whoever came up w/that drive line needs to be whipped. An air-cooled automatic transmission? No thanks. Along w/the support bearing in the d-shaft, and a small diff- they sure didn't do us any favors... |
I suspect that is why the stock driveshaft has a CV joint at the center bearing instead of a simple U-joint - to avoid vibrations. This build will be an adventure. |
| 67 Mustang Cable Clutch Conversion | caustin | Transmission - Rearend | 3 | 02-10-2008 02:21 PM |
| Roll Bar Install Advice | Mustangsaly | General Rodding Tech | 12 | 12-02-2007 08:33 AM |
| Need Help ! - Chevelle / Olds 442 Clutch Linkage | MARSHMAN 442 | General Rodding Tech | 1 | 09-10-2007 08:53 PM |
| Clutch linkage problems-Centerforce??? | baddbob | Transmission - Rearend | 1 | 03-09-2007 08:50 AM |
| clutch cable on a 97 HD??? | akm | Hotrodders' Lounge | 8 | 05-29-2004 11:05 PM |
