Conversion Ford Ranger V-6 to a V-8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-04-2008, 07:33 PM
Hi,
I am building a "Rat Rod" and have a '92 Ford Ranger Frame and a 351 W and a AOD trans that I would like to put in then add the other parts.
I am wondering if any one has made this conversion and what did they use for motor mounts other than Advance Adapters mounts and as always there is the old "Plenty of time but not enough money for aftermarket parts"
It would be a big help if some one has done this conversion and how they set up or made the the motor mounts.
Thanks
Old 03-04-2008, 08:07 PM
Kruzin Karl
http://www.rangerpowersports.com/tech/?cat=6
Old 03-06-2008, 07:35 PM
KA67_72's Avatar
For engine mounts on my ranger I bolted flat 3/16 plate to the block and welded it to the frame. I'm running a C-4. For the trans I made a short extension from the crossmember to the trans mount. It cost about $5.
Kevin
Old 03-06-2008, 08:06 PM
motor mounts
im pretty sure u can get motor mounts from vip ect look at the AA catolog after i bought mine from them (AA)they were just over the counter items. i think they come from a van or mustang, its been a few yrs since i did my ranger swap
Old 03-07-2008, 01:32 AM
Ranger V-8 conversion
Hi,
Thanks for sending the information on the Ranger swap
You used a 3/16 plate and bolted to to the block then welded it to the frame
Did you have any problems with engine tourqe breaking the welds?
Did you brace the 3/16 plate?
What other clearance problems did you have?
Thanks again,
Ford Wagon
Old 03-08-2008, 12:50 PM
KA67_72's Avatar
I welded the plate on three sides to the top of the frame and welded a couple braces down to the crossmember. I'm running 15 psi into a 302 and haven't broken the welds but it is traction limited.
Kevin
Ford 302ci In A 1984 Ranger 4X4? izzymiddleton Hotrodders' Lounge 26 12-10-2014 02:55 PM
37 ford conversion to later ford hydraulics 37ford4dr Suspension - Brakes - Steering 4 11-29-2006 07:46 PM
Ford Ranger manual steering box ? AC/DC Suspension - Brakes - Steering 12 08-12-2006 07:41 AM
Ford Ranger and Mazda 49olds Suspension - Brakes - Steering 10 11-07-2004 10:44 PM
Whatever happend to these guys? hot_rod_kid Hotrodders' Lounge 20 12-17-2002 10:20 AM
