convert ext reg to internal reg alternator - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-06-2008, 06:51 PM
I have a 72 Nova SS, 350 converted to HEI. It has an external voltage regulator and I want to know what is involved with converting to an internally regulated alternator and eliminating the ext regulator that is mounted on the core support?
Thanks, Inovater72
Old 03-06-2008, 07:50 PM
Holder350's Avatar
Auto Parts Professional
on the new internal regulated alt theres a plug-in with 2 wires IIRC looking from the rear of the alt, the wire on the left is the remote....that wire goes to a 12v switched source - you should have one to the external regulator. Then the output wire goes to either the battery or the battery terminal on the starter.
Old 03-08-2008, 09:56 PM
See if this applies: http://67-72chevytrucks.com/vboard/a.../t-119379.html
Convert from generator to 10Si GM alternator KENMO Electrical 7 08-12-2007 08:05 AM
G M Internal Regulated Alternator Rob Keller Electrical 62 04-22-2007 02:05 PM
another frustrating alternator problem darom Electrical 13 04-09-2006 11:09 AM
Bad Alternator or Voltage Reg.? BlueByU Electrical 10 05-31-2004 08:11 AM
Wire In Alternator [ Internal Reg ] Paul K Electrical 0 02-29-2004 03:53 PM
