convert from map sensor to mass air flow - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-09-2003, 05:03 PM
New Member
Post convert from map sensor to mass air flow
I have found the solution to my 302 problem. I need to know how to convert my 92 EFI 302 from a map sensor to a Mass Air Flow. It is common on mustangs to do this and i need to know how.
Old 05-09-2003, 05:47 PM
HotrodLincoln's Avatar
Hammer King
Last journal entry: paint job
Post
Try this:
http://www.corral.net/tech/powerplant/maf_tech_2.html
It explains the proccess well. I have done this several times, takes the beginner about 1.5 hours. The hardest part is finding a computer (supply and demand thing). I like to use the "A9L" computer for a standard-trans Mustang.
Take your time, solder all connections. You will end up with nice results.
[ May 09, 2003: Message edited by: HotrodLincoln ]</p>
Old 05-10-2003, 07:29 PM
New Member
Post
how much does this usually costs?
