meth 2 gas
why would you want to?what is your comp ratio?methenol is cheaper to run than race gas,runs cooler,& you need that in a vw in hot weather.just change the fuel pump,and jetting on the carb.check out my alky burner,the only way to fly at the track,sand,street.alky burns 2 gal of fuel to every 1 of gas,but more power is made do to the cooling aspects of the alky http://www.hotrodders.com/forum/jour...ge=1&reverse=1
methanol to gas
I don't know what the compression ratio is and i want to switch back to gas for convenience purposes. This is not going to be a racing application anymore, but it used to be for sand drag. I just want to play
your lost
rejet the carb,and a new fuel pump for gas,if you were going to gas to methenol you need a carb with hardened needel seats and plastic floats methenol compatable.hes going FROM methenol to gas end of story,your fuel lines were used for alcohol wich is corrosive and if they were set up originaly for methenol should be fine.run som marvel mystry oil mixed with gas thru the lines to remove any crap,methenol atracts water and gels and if not maintained may need replaced.the pump needs to be changed due to fuel preesure and volume
| Gas Thieves!!!! | Weimer | Hotrodders' Lounge | 28 | 03-03-2010 02:46 PM |
| Question about gas grade??whats best?? | Robbie | Engine | 18 | 07-09-2004 10:59 PM |
| want cheaper gas prices?? plz read this | sherfield2002 | Hotrodders' Lounge | 7 | 03-12-2004 05:22 AM |
| priming for 1st start w/new gas tank required? | bullheimer | Engine | 4 | 08-09-2002 07:05 AM |
