Convert My External Reg to Internal Reg - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-06-2011, 07:58 PM
JP72's Avatar
I'm pulling whats left of my hair out....
I want to update my Nova to an intermal regulator caus I can't seem to get the external regulator to work.
Problem: External regulator mainains battery voltage until I use an accessory then it drains and eventually will die. It takes a while, and the GEN light is on but dim.
SOlutions: I disconnected every ground and cleaned the connections, replaced the Battery, Alternator, and regulator. I also installed a ground from the engine to the frame and from the battery to the body. WTF ? Driving me nuts.
Problem 2: Bought internal regulator alternator and followed the wiring steps as follows:
Eliminated white wire and priovided constant power to battery, from field plug on alternator, other field plug I connected to brown wire for GEN light and I left the one power wire on back of alternator as it was. Tested and voltage was at 18 on the meter NFG..
I was able to get both alternaotrs warrentied and have a new regulator but have not hooked anything up as of yet, I thought I would ask for some help...
PLEASE? Anybody
Old 07-06-2011, 08:16 PM
Cape Cod Bob's Avatar
Maybe this will help u.
http://www.oldengine.org/unfaq/10si.htm
Old 07-06-2011, 08:27 PM
JP72's Avatar
Thank You, I'll give it a shot,,, it sounds like what i did the second time but I may have reversed the 1 and 2 terminals...
Thanks again.
Old 07-07-2011, 03:51 AM
EOD Guy's Avatar
See your other post on the same subject
Old 07-07-2011, 09:28 AM
A picture is worth a thousand words.
Old 07-07-2011, 03:46 PM
EOD Guy's Avatar
yep same one I attached to the other post
Convert External Regulator To Internal Regulator 83F150 Electrical 1 05-18-2008 08:10 AM
383 internal or external balance johnbelanger Engine 15 01-15-2008 04:32 PM
Internal... External... Balance that 383!! KSailer77 Engine 8 06-09-2007 08:22 AM
460 external or internal thames Engine 9 10-08-2002 02:12 PM
Internal vs External dollybud Electrical 4 08-05-2002 06:48 PM
