Convert speedo to Electric - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-19-2012, 08:25 PM
I want to keep the gauges I have, so I need to convert the speedo to electric.
I see services offered from vendors:
http://redlinegaugeworks.com/
http://classicinstruments.com/
But, could I just go to the car I got the engine/trans from (2002 LS1) and rig up the works behind my face and pointer? (I know I just made that sound real easy).
The other gauges (Temp and gas) are pretty simple. The Amp to Volt may be a bit tricky- I will take advice here also- I admit I have not done much searching on that subject.
Thanks,
Charles Major
Old 03-20-2012, 05:59 AM
Everything you want to do is possible, but the amp-to-volt change will take a differentr meter movement.
Amp meters go in series with the power line/source and reads Current, a volt meter goes from the main line to ground and reads Voltage.
I think I'd get ahold of either of the suppliers you listed and ask them directly.
Old 03-20-2012, 12:37 PM
RippinRon's Avatar
First things first what are working on? What have you swapped in. If you've swapped a LS1 and matching tranny it will all ready be electric. The ECM take the signal from the VSS (vehicle speed sensor) and controls the speedometer.
Old 03-20-2012, 12:44 PM
RippinRon's Avatar
Here is another recent thread if this is what you are trying to do. The search function is a beautiful thing.
Old 03-20-2012, 12:54 PM
I do have an LS1+trans from a 2002- It is going into a 1953 ZIM Russian Goverment Limo (Like a 1950 Imperial with jump seats). Sorry I dont mention the car much as some people dont want to put a Commie car on the road.
So I dont really want to convert the electric signal to a mech drive (I did find that thread in my search and agree that GPS tool is cool). I want to keep the face but put the speedo works from a 2002 LS1 car behind- I know I need to flash the computer for the bigger tires.
Thanks
Convert seats from computer-controlled to simple electric? jamieson Electrical 3 12-19-2011 01:31 PM
Trans/Speedo convert. DoubleVision Transmission - Rearend 4 08-29-2011 07:48 AM
how do I convert to electric wipers? (1930-34 chevy) Riley Hotrodding Basics 4 08-08-2010 04:20 PM
How to convert vacuum windshield wipers to electric willys36@aol.com Electrical 2 12-10-2004 06:01 PM
On Q-Jet Can a hot air choke convert to Electric Auto-Part Engine 11 12-05-2003 05:23 PM
