Convert T-400 to a FULL manual valve body - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-27-2012, 12:18 PM
Can l do this without buying the whole kit? If l can, can l do it with the transmission still in the truck? Thanks
Old 04-27-2012, 04:27 PM
[QUOTE=fordss]Can l do this without buying the whole kit? If l can, can l do it with the transmission still in the truck? i would like to make it shift all 3 gears with out the governor thanks
Old 04-27-2012, 04:58 PM
Buy the valve body and related parts from TCI, Hughes or other. That's the only sane way to try unless you're a trans wizard. You CAN do it in the truck.
The biggest problem could be installing the plug where the modulator used to be. You will want a new shifter with some type of gate as most all manual valve bodies are reverse pattern.
Old 04-27-2012, 09:06 PM
how do i know what it is reverse pattern or Forward. tranny out off 1976 caddy thanks
Old 04-28-2012, 07:22 AM
Every factory trans is forward(standard P-R-N-D-2-1) but the manual valve body is reconfigured to be P-R-N-1-2-3 so in race situations where you might get a little twitchy, you're shifting away from neutral, not toward it. That's the difference/advantage.
Old 04-28-2012, 10:01 AM
Crosley's Avatar
Wiki Edits: 1659
Full manual shifts on a T-400 can be forward or reverse pattern.
You need to decide what you want and check for costs and / or shifter changes for reverse pattern depends on shifter you have or will purchase
Full manual valve body t wajouba Transmission - Rearend 2 09-08-2009 05:21 AM
C4 full manual valve body Sixtyninemercury Transmission - Rearend 8 06-04-2008 06:33 PM
Full Manual Valve Body Marcus Transmission - Rearend 8 04-12-2008 02:47 PM
Full manual valve body Marcus Transmission - Rearend 3 03-01-2005 12:58 PM
Full Manual Valve Body TH-400 Chezelle Transmission - Rearend 3 06-13-2003 06:47 PM
