I installed several of the conversion kits years ago. The kit converts full time 4x4 transfer cases to part time with locking hubs on the front axles.
You do not mention any problem, so I do not understand why you would want to look for a 208 to install. Tony
At the Bonneville Salt Flats, first gear is known as 130 mph. |
Tony,
Thanks, that in itself sounds reasuring. I was just not sure about the conversion. I didn't know that they pretty popular. Is the shift pattern 2h, n, 4h, 4l ??? Also, would there be any problems mating this to a 700r4? I have one I'd like to put in this truck. Thanks for your help. |
With the correct 700 output shaft the unit should bolt to the transfer case.
The 700 bolts are all metric. 10mmx1.5 is the correct bolt size and thread for the rear of the case on the 700
