converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-08-2005, 10:20 PM
Stupido1's Avatar
74 NovaSS
converter
I just purchased a brand new B&M torkmaster 2000 converter. How much tranny fluid do you need to fill it with prior to installing it? 2,3,4? quarts
Old 04-09-2005, 02:04 AM
AngliaBob's Avatar
It just takes time and money
Last journal entry: Specifications
Stupido1,
You'll be ok with 1/2 to 3/4 of a quart in it. If you put any more in, it will run out when you install it on the trans.
Bob
Old 04-09-2005, 11:35 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
Convertor
I fill it up and turn it upside down to drain off the excess. Use a thin layer of vaseline on the shaft so you don't burn your seal.
Old 04-10-2005, 12:21 AM
Stupido1's Avatar
74 NovaSS
would it have the same effect if i just Thoroughly rubbed the shaft with tranny fluid?
And one more question. When attaching the converter to the flexplate, do i need to use washers for the 3 bolts, or are the bolts strong enough. The new bolts came with the new converter.
Old 04-10-2005, 12:34 AM
bracketeer's Avatar
489 Lemans
convertor
Putting tranny fluid on the shaft can cause it to leak. There is a special lubricant for the convertor and yoke. When you don't have the lubricant B&M recommends vaseline.
No washers. The bolts are designed for shear strength not stretch strength. Bolts go through the convertor with nuts on flex plate side. Flex plate humps go towards convertor.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-27-2004 12:32 AM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 03:57 PM
what does lockup mean 67bird Transmission - Rearend 31 02-25-2004 11:21 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 07:53 PM
