Converter - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2006, 01:14 AM
Converter
I have a 383 stroker in my 1970 Nova and I am using a cam with specs: 240/246 @.050 and .541"/.544" lift. I have 10.5:1 compression, AFR 195cc heads, 3.73:1 gears and a th-400 trans. Just installed cam and don't know if I should go with a 2500 or 3000 stall speed converter. Which would you recommend and is there really a difference in brand, TCI or B&M? Don't do a whole lot of street driving, not an everyday driver. Thanks a lot for the help.
Old 02-24-2006, 11:27 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I'd go with the 3000, but the gears and light car would work OK with the 2500.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 01:42 PM
B&M Holeshot converter opinions RObs71Nova Transmission - Rearend 4 08-14-2005 01:04 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-27-2004 12:32 AM
Converter ballooned ?!?!?! Slant3 Transmission - Rearend 2 06-13-2004 09:20 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 07:53 PM
