Converter to Flexplate Torque Spec? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2009, 02:12 PM
Just a quick question. I have a 454 and a TH400. I need to know the torque spec for bolting the converter to the flexplate.
Right now there is a gap between the converter and flexplate. Are there spacers or shims i use or just pull them together and bolt it up?
Old 12-22-2009, 02:26 PM
38mike's Avatar
Careful, there matey!!!!! The convertor should pull right up to the flexplate with minimum force. Don't use the bolts to pull them together and you shouldn't have to use any spacers or shims. Be absolutely sure that you have the convertor totally seated into the tranny (it should turn relatively easily after 'clunking' into place) and then, when the tranny is installed, the convertor should pull (without to much effort) back forward far enough to reach the flexplate. If there is ANY need to crank down the bolts to pull them together, you need to watch carefully as somethin' ain't right.
Old 12-22-2009, 02:32 PM
No it spins very easily and i can pull them together with ease.
Torque spec?
Old 12-22-2009, 02:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
If i remember correct it is torque spec is at 44 ft lbs. But i dont torque mine just make sure they are good and tight i will probably get for this but thats how i do my own stuff.JMO
Cole
Old 12-22-2009, 02:45 PM
Cole
LoL I usually just tighten up my bolts as well but when they are bolts that are "in motion" or have some type of critical duty other than holding two pieces together, i try to use the proper torque specs.
Plus i like to use my expensive torque wrench every now and then...
Old 12-22-2009, 02:53 PM
eloc431962's Avatar
Wiki Edits: 37
I totally agree better safe then sorry
Cole
Old 12-23-2009, 01:53 PM
I use grade 8 bolts with nyloc nuts tighten them up good and the nyloc will keep them from backing off
Old 12-23-2009, 04:18 PM
i use to do that but i had a set come out on a trip from pa to alabama tore the threads all up had to have it welded to get home i make sure their to torque with a torque wrench now
Transmission swap: TH250 to TH350 Torque converter issues. 35oldstruck Transmission - Rearend 5 05-21-2008 03:43 PM
Torque converter question(s) chrisflock Transmission - Rearend 3 11-10-2006 11:41 AM
Ford 4R70W torque converter interchange? sweet99 Transmission - Rearend 1 11-09-2006 03:04 PM
Torque Converter Question leejoy Transmission - Rearend 5 10-02-2006 11:57 AM
Building a SBC to rev to 8k, and have power Andyrew Engine 52 04-17-2006 12:46 PM
