I have a 700R4 and have it wired up so that the converter should lock up. I have this switched so I can turn it on and off but notice no difference between switch positions, should I? How can I tell if the converter is locking up? Thanks in advance!
This is a good question, because I've got a 200R4 and the TCI switchable control. The switch doesn't seem to do anything. All I know is when it shifts into 4th my rpms drop waaaay down. Other times, it seems like it is locked up in other gears too.
There is 2 shifts, then overdrive. which feels like 3 shifts. You should be able to hear and feel the lockup take place.
Sometimes when I think mine is not working, I touch the brake pedal at cruising speed , and feel the difference. Also there is a 300-400 rpm change.
Troy
If you don't make mistakes. your not doing anything.
69 SS/RS full custom Camaro 98 ISCA Grand Champion
69 SS/RS BB Camaro wifes driver
66 Elcamino 350/all dz parts,ac,windows,loaded,my driver
69 SS Chevelle BB conv.fresh frame off
26 T sedan street rod
Ok,
So if I am making it into overdrive (3 shifts) then the converter is locking up??
I guess now another question that this brings to my mind is the 700r4 a true 4 speed transmission or is the converter lockup what gives you the final drive ratio??
If I just had three pedals and a stick coming out of the floor this would be alot simpler for me
The converter locking up (like a clutch and pressure plate) is independent of the gears you have available from your transmission.
The easiest way to feel, stab the throttle briefly at a fairly slow speed but still in O/D (4th). If the revs jump, but the car doesn't you're not locked up. If the revs can't jump and it feels like it would if you stabbed the throttle with a manual - you are locked up.
The 'shift' feeling comes from when the converter locks up. It is no longer allowed to slip so the revs drop a little at speed and it can feel like a slight shift to some people.
Lance, you're certain you wired up a switched negative lead to the converter?
edit - btw, do you guys use a vaccum switch to help work the lockup feature?
Thats the way they are wired from the factory, through the brake light switch.
Troy
Related Threads
Hot Rod Forum
2.2M posts
175.6K members
Since 2001
