Converter Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-09-2003, 08:23 PM
MI2600's Avatar
Member# 3287
Converter Question
Is there a way to check to determine if a converter is bad?
I've got a rebuilt 200R4 that seems to be slipping. I reused the old converter from the old trans which had similar symptoms. I'm wondering if the converter wasn't the cuprit all along.
I've adjusted the TV cable til I'm blue in the face.
Any ideas are appreciated.
Old 09-10-2003, 04:47 PM
MI2600's Avatar
Member# 3287
Aw, c'mon guys. There's nothing I could find in the KB. Somebody must have some knowledge.
Old 09-10-2003, 05:44 PM
gt2betubbed's Avatar
Kid With A Wrench...
Last journal entry: The Blower and test fit.
I searched around, and even called a tranny shop here in town. They said the only real way is to pop it out and take it in. They then can check it out for "excessive wear". Here's a thread I found while searching in google also.
http://www.hotrodders.com/t19969.html
Old 09-10-2003, 05:51 PM
willys36@aol.com's Avatar
Wiki Edits: 21
Used converters with a new tranny is a no-no in my book. Good, high performance converters are so inexpensive (relatively) that it isn't worth taking a chance on an old one. Yes, your converter is likely the source of your problem.
Old 09-10-2003, 06:36 PM
MI2600's Avatar
Member# 3287
Thanks guys. I knew someone could help.
I guess I should have asked this question before it went together.
Old 09-10-2003, 07:21 PM
roys63's Avatar
I have a Friend that had the same problem and a trany shop told him to shim the converter back off the flywheel pushing it in to the pump deeper, i don't remember how much but it did cure the problem. I have seen new performance converters that came with the shims to do this . You must be careful how much you shim it or it will not center in to the crank support.
Old 09-10-2003, 07:58 PM
adtkart@aol.com
Ever since they came out with the Lock-up convertors, I have been against re-using a convertor out of a transmission that wasn't working right.
As far as using shims to move it into the pump farther, never heard of such a thing. If it was a "Reman" then maybe it has the hub on it wrong. Maybe it isn't out as far as it should be. The hub goes into the pump and turns the gears. It won't only "partly" turn them. If it isn't in the pump right, it WILL wipe out the pump and gears. I never had to shim any back.
Old 09-10-2003, 08:22 PM
Shimming the converter will only put more stress on the flex plate, which may damage the flexplate or wipe out the pump or bushing.
If the converter was bad it wouldn't make the transmission slip. You may have no torque multiplication if the stator is bad though. That's easy to check when you have the converter out.
Why don't you start over and tell us what your problem is and perhaps you can isolate the cause.
More info
Old 09-11-2003, 06:39 PM
roys63's Avatar
Yes that was the wrong info for that problem, he had a couple different trans and converters in that car within a week, one of the converters he was using was custom made for a mid-plate and he had to shim it , Sorry about that!
Old 09-11-2003, 07:25 PM
MI2600's Avatar
Member# 3287
Ok. From the beginning... '86 ElCamino purchased with a 305 and a 200TH trans. It slipped most noteably in second gear. I replaced the 305 with a 406. Then I replaced the 200 with a 200R4. I finally got the TV cable adjusted to where it will shift at acceptable speeds, but it still slips in second. I bought the 200R4 from a rebuilder. He threw in a used converter, but he told me it had high mileage. The converter appeared identical to the 200, so I used the 200 converter.
Any ideas?
