converter Recommendations - 550+ ft/lbs - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2005, 02:24 PM
fearsomefairmont's Avatar
Hi Folks,
I have been doing some more work to my '72 Olds with a 455 and TH-400.
I will be installing ported C-heads, a larger cam, 240@.050, .480 lift, and rhoads lifters to make the idle a little bit more mild. Correspondingly, I will be installing a different torque converter.
The stall range I would like would be around 2700-3000 rpm. There is also a plate nitrous system in the works, 150 hp shot. What I would like is a converter that won't frag behind 550+ ft/lbs of torque in a heavy (442 A-body) car.
If you have any suggestions I would appreciate it. I just don't want to buy some random converter from Jegs and have it blow up and take out the trans, which has been suitably modified for the power levels. Please forward any suggestions or personal experience you have with different companies. I have heard some horror stories especially about B&M. I just see lots of companies out there, ATI, Coan, TCI, etc. and don't know which to choose.
Thanks for your suggestions,
Andy
PS If it is inexpensive that is a plus.
Old 05-06-2005, 07:28 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
You do not want to go cheap $ on a converter. think quality first then price. every thing iis a trade off as I am sure you know.
You must know the 455 is a torque monster motor.
With Nitrous use..... anti balloon plates are recommended on the converter
I would suggest you call Hughes Performance M-F , ask for Mark.
1-800-274-7223
Old 05-08-2005, 11:55 AM
Thanks for the recommendation
Crosley,
Thanks for the recommendation. I will give them a call soon. I am still in school now (final exams - sucks!) but am looking forward to hauling my ride to the track with a failure-free converter.
Andy
PS The olds 455 really is a torque monster. Makes a great street motor just because of that, even in its 8.5:1 form with smog J heads and stock converter it is a low 14/high 13-sec ride.
Old 05-08-2005, 01:19 PM
S10xGN's Avatar
Gotta love a turbo!
My GN powered S-10 makes around 550 ft-lbs (at 24# boost) and I'm completely happy with my Precision Industry "Vigilante" 9.5" lockup converter. It remains comletely docile around town, but stalls at 3600 @ 10# boost which makes for a very satisfying launch! If I were to do it over, the only thing I'd do different is to lower the stall a few hundred. The shift light stays on for damn near the whole run!
Old 05-08-2005, 06:46 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Stall speeds are tricky to hit with a small turbo motor.... when the turbo spools up and turns the small motor into a larger motor( boost!)
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
TH350 gap between converter and flexplate QUESTION chrisgarrison Transmission - Rearend 6 12-26-2004 11:32 PM
Torque Converter Application BMRIde85 Transmission - Rearend 4 06-17-2004 02:57 PM
Converter ballooned ?!?!?! Slant3 Transmission - Rearend 2 06-13-2004 08:20 PM
possible bad toque converter? Deadtemple Transmission - Rearend 9 10-11-2003 06:53 PM
