converter stall speed? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2006, 08:19 PM
Prof. T. Soggmeyer's Avatar
Plan B
I have a basically stock 283 joining to a 700r and was wondering what stall speed do I need for the converter.This is the first automatic I have done so I don't have any experience to gauge this by. I also have only dealt with 350's and VW's. I am guessing 1800 judging by my 350 in my Burb but I think a 283 might need a faster one? Anyone know ?
Brad... (soggy T.)
Old 11-09-2006, 08:56 PM
techinspector1's Avatar
Wiki Edits: 326
If you have a basically stock motor, then a basically stock converter would work well, particularly with the low first gear of the 700R4. If you wanted a little more pull in first gear, you might go with the most modest offering by your favorite converter manufacturer. In my opinion, 1800-2200 would be perfect.
Old 11-09-2006, 09:17 PM
coldknock's Avatar
Take your little 283's lower torque into consideration when you select an off the shelf converter. It does not make as much torque as a 350 and the converter will probably not reach its advertised stall speed. Depending on the weight of the car, camshaft specs, and compression ratio it could be 300-400 rpms lower than advertised.
Larry
Old 11-09-2006, 09:20 PM
Banned
I would go with a 2,000 convertor, primarily because of the reduced torque from less cubes... If its a very well built 283 then maybe you can go with a stock stall, but its gonna be a little more sluggish than a 350.
Old 11-09-2006, 10:24 PM
stoney 81ta's Avatar
Dont want to go off topic here,but being new to performance builds ,how and what does a torque do and what is the basic stall in a stock 350.
Old 11-10-2006, 07:37 AM
Originally Posted by stoney 81ta
Dont want to go off topic here,but being new to performance builds ,how and what does a torque ( converter ) do and what is the basic stall in a stock 350.
Jim Hand wrote a nice article on converters:
http://www.pontiacstreetperformance..../Twisting.html
I don't know what the stall speed of a stock GM converter is, but I would guess in the 1500-1800 rpm range.
Old 11-10-2006, 08:38 AM
Thanks Onovakind67 good and informative reading.
TCI Stall Converter - Blown SB 68NovaSS Transmission - Rearend 10 09-09-2008 12:42 PM
please recommend me a stall converter smlblcks10 Engine 6 02-09-2005 05:41 AM
B&M stall converter Lthompson Transmission - Rearend 6 11-29-2004 03:04 PM
Stall Converter Info?? trick66 Transmission - Rearend 14 10-31-2003 11:19 AM
stall speed? Thacolbster Transmission - Rearend 10 09-09-2003 02:48 AM
