Converters: flash, rated, brake stall - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-06-2008, 01:28 AM
I Have a 3300-3500 Dacco PP3402 Pro-Competition stall converter. I have read a lot of info on different T/C's, but i'm still confused on exactly how they work. I know they let your motor rev to a certain RPM before locking up, and i understand that.
I found these 3 terms in my research, and I don't understand if these are 3 different types of converters, or just ways you can use them? I know Flash is when you mash it to the floor from idle, and brake stall is when you hold on the brake how high your rpm comes up before the tires start spinnin, and rated is what the typical rating is like mine is 3300-3500.
I guess I wanna know if I'll be able to stand on mine at an idle and have it flash to the stall speed or if i have to brake until it locks or what???
Also if anyone is uses Dacco's or knows much about them, How do i find out the SRT (stall rated torque) or (multiplying factor) of my converter??
Old 10-06-2008, 07:31 AM
espo1980's Avatar
If it doesn't fit force it!
re: Converters: flash, rated, brake stall
Good question eatonde. I've never understood them and would like to. Please somebody explain!?
Old 10-06-2008, 10:50 AM
Jmark's Avatar
yep, Google is saving the world!! LOL
http://www.summitracing.com/streetan...xplained here.
Mark
Old 10-06-2008, 10:52 AM
Bench racer
As F-bird said, google will give you an encyclopedia of information on this..
Here's a start. Covers the basics:
http://www.kennedysdynotune.com/Torq...ter%20Tech.htm
Old 10-07-2008, 12:44 AM
converters
Thanks for the info guys, but I still can't find much on my particular converter. I'm really curious what the stall rated torque is on my converter. I know they are all different. I have seen some that are 1.6, 1.7, 2.4, 2.6, and so on. I bought my converter from a friend that had it and never used it. It was still new in the box but didn't have a lot of info with it. Even if i go to Dacco's website the SRT is not listed on any of thier converters. If anyone out there can provide this info I would greatly appreciate it.
Danny
off brand stall converters levens Transmission - Rearend 3 04-25-2005 12:16 AM
which stall to use.. Lthompson Transmission - Rearend 6 02-08-2005 04:31 PM
Street use of higher stall converters Mad Maggot Engine 27 01-29-2005 11:40 PM
stall converter adam15425 Engine 26 10-15-2004 06:50 PM
stall converters madhat Transmission - Rearend 2 08-28-2003 06:30 PM
