Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Convertible on rottiserie
Old 11-18-2012, 05:55 PM
48cad 48cad is offline
Chris Ryan
Having done several frame off convertibles...... I'm assuming all gaps and panels fit well now? 1" square tubing is cheap. I would brace it, and just not one bar across door openings, triangulate it. Also When you remove body bolts and lift the body off...... draw a diagram of the mounts and take notice of the body shims and their thickness. When you reassemble, there will not be as much guess work when it comes to properly shimming the body. Its amazing what a difference a 1/16th inch shim, the whole way in the rear of the car can make in a door/quarter panel gap.
The Following User Says Thank You to 48cad For This Useful Post:
69 widetrack (11-18-2012)
