Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Convertible on rottiserie
Old 11-18-2012, 06:49 PM
mr4speed mr4speed is offline
Have done a couple of mid fifties caddy convertibles off the frame and put on a rottiserie, of which neither cars had any rust problems. But I will say this when you bolt a car to a rottiserie your putting an extreme amount of force against the center of the car , because you are attaching the jig at the very ends of the body forcing pressure in the middle. If you are lifting the body off the chassis with a 4 post lift, your most likely lifting evenly from the center of the body. Not so with the rottiserie, as John L has stated it is cheap and easy just to brace the jamb so all that pressure won't be able to move anything. With a coupe or hardtop the roof is keeping the car from bending, unless you have some serious structure rust problems. By the way you can use your rottiserie as a 4 post lift to remove the body and reinstall it as well, providing that the wheels are not welded on and can be removed. DO NOT attempt to do this with the wheels attached.
