Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Convertible on rottiserie
  #34 (permalink)
Old 11-23-2012, 05:39 PM
69 widetrack 69 widetrack is offline
Faith - Respect - Trust
Yes it is for many of them. That is why you need the bracing. Many times if you open the door on a convertible on a frame lift you can not close it again until you let the lift down.
Exactly right John, the bracing should go on before the car is lifted front or rear, 1/4 inch now in the door gaps when somebody leans on it, can you imagine if it's not braced and over time, turning it around a few times to work on the bottom??? Get the car level with even weight distribution, if at all possible with the doors on and brace it.
