Convertible top installation question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-21-2005, 09:56 PM
wilke's Avatar
Wilke
Last journal entry: The More Door continued
I'm looking for information or photos on how to install the foam 'stay pads' under the convertible top canvas on my 1971 Olds Cutlass. The car has no material at all on it to use as reference. I bought a Kee top from The Parts Place Inc, window, pads, tack strips, etc. I have the Fisher Body Service manual, but the instructions about the stay pads are not real clear to me. <P>
Do the stay pad 'sleeves' go on with the slit up? Fasten them first, then glue the foam pads inside? I'm assuming the wide end of the sleeves go toward the back? Please help. Thanks.
Old 09-22-2005, 12:29 PM
poncho62's Avatar
Wiki Edits: 5
I did my 62 Pontiac roof at home.....a long time ago. If I remember right, the pads already came with the foam installed, so I can't help you, if they are separate. the hardest part, other than stretching the top, was making sure the back bow above the window was in the right position. the measurements for that are in the GM manual.
Ontario Rodders
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Convertible top help VWFan Interior 1 10-17-2004 01:34 PM
Convertible Top Motor 65 Chevy EazyDuzIt102 Electrical 1 08-10-2003 01:23 PM
Convertible top for pick-ups? Casonoma Body - Exterior 16 07-31-2003 07:01 PM
CHOPPING CONVERTIBLE TOP FRMNDA1 Body - Exterior 0 12-09-2001 07:22 AM
