Convertible Top Pads - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-12-2011, 06:43 AM
Hey Guys, has any of you ever bought WHITE top pads for your convertible? I need a set for my 65 Mustang! If so, where did you get them? Thanks, J-ree
Old 10-12-2011, 06:53 PM
The top kits I have worked with have the pad materials with them. All the white tops I have used had black on the under side as well as the pad covers. It would be easy enough to substitute white material for the black.
Trees
Old 10-13-2011, 05:47 AM
Hi Trees, thanks for the info. I put a white liner on my top to brighten up the inside and wanted every thing to match. I'll look into your suggestion. J-ree
best typ of break pads ? THERACER Suspension - Brakes - Steering 4 10-26-2009 10:11 AM
sanding pads smrat Body - Exterior 2 10-06-2008 07:02 AM
Brake Pads ** Javelin69 Hotrodders' Lounge 3 12-27-2007 02:12 PM
Scotchbrite pads texczech Body - Exterior 13 04-20-2007 05:58 PM
Can I use the same pads? Malibucdl Suspension - Brakes - Steering 5 08-04-2006 07:45 PM
