You can hand stitch your top and get it almost as good as machine sewed if you take your time and are careful to go through the original holes in the fabric. You will need polyester thread the same size as the original which will probably be size 138. The only other thing you will need is a small curved needle, and an infinite amount of patience. Sew up and and down every other hole like in the pictures, and when you get far enough to repair the open area, reverse directions and sew opposite of the way you sewed the first time. Make sure you start and stop from underneath to hide the ends of the repair. The only other thing to remember is to not sew through your thread. I used great big twine and a large needle for this example. Regular stitching looks like the other two rows.
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
Wow! Thank you for taking the time to make up that demo and photograph it.
That's exactly the information I needed. For better or worse, patience and attention to detail are part of my character. Sometimes it's a curse, especially if you ask my wife. Just a few questions if you don't mind... To start, do I just tie a knot at the end of the thread so it doesn't pull through on the first stitch, or do I make a single stitch and tie that as a loop to start off? Or is there another method I should use? Similarly, what's the best way to tie off the end when I'm done? Is it best to do a repair area with one continuous thread back and forth or doesn't that matter? |
When you start from underneath, just leave a long piece of thread. When you get back to that piece of thread , tie a square knot with the two ends you will have. Sorry anbout that, I thought I posted the picture of the square knot, but I didn't.
Yes, use one continuous piece of thread to make each repair. You'll need a 4" 17 gauge curved needle from an upholstery supply place. CLICK HERE
| Recent Interior posts with photos |
| convertible top | old fords | Body - Exterior | 3 | 12-29-2008 08:22 AM |
| convertible top | newk | Body - Exterior | 1 | 07-10-2006 05:10 PM |
| do it yourself convertible top | RedRobster | Body - Exterior | 3 | 02-24-2006 08:55 AM |
| Convertible top help | VWFan | Interior | 1 | 10-17-2004 01:34 PM |
| convertible top vs. hard top | billyr | Body - Exterior | 2 | 02-21-2004 06:48 PM |
