Converting a 1996 LT1-4L60E to manual transmission - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-04-2012, 05:40 PM
I have a 1996 Camaro LT1 with a 4L60E automatic transmission that i installed in my truck. I am considering changing the transmission to a 5 speed manual transmission. Does anyone know if a tranny out of a 90s chevy pickup with a v8(small and big block)will work with my motor?Does anyone know what flywheels will interchange with the motor? Will a standard small block flywheel work or do the LT1 motors have something special that requires a unique flywheel?
Converting LT1 heads for use on SBC Silverback Engine 40 12-20-2010 07:23 AM
1996 GMC 4L60e ovehaul transmission; having some problems redmex Transmission - Rearend 1 09-07-2009 08:44 AM
converting LT1 to 4-bolt curtis73 Engine 3 03-30-2008 06:53 PM
Converting a 95' lt1 to carb set up. GearheadSean Engine 7 05-21-2007 07:48 PM
350 converting into a LT1 HammerZ28 Engine 2 11-24-2005 06:06 PM
