converting from 4X4 to 2WD
I recently bought a 1985 S-10 4X4 to be used as a work vehicle I really didn't want a 4X4 but the price of the vehicle was gooood. After getting the truck home and really looking it over I noticed that the CV boots were torn and I think I hear clicking from the CV joints.
My question is can I just remove the CV joints and front axle shafts and leave the axle stub in the hub than remove the front driveshaft? I don't want to put more money into the truck than I paid for it. Thanks - Jerry |
No -- that would not work.
Don't know your budgetary situation, but I think your choices boil down to replacing the joints when they go if you can tolerate being F.O.R.D. (found on road dead) when they go, replace them now for durability, or just scrapping the truck when they go. My past experience is that replacing them has not been that expensive (if you have a good and reasonable local mechanic)> |
if the cv joints died, wouldn't he (hopefully) be able to somehow tie them 'up' so the shafts don't hang down into the suspension?
p.s. after it breaks and you're going to scrap it, have some fun with it.
IIRC, Both CV shafts bolt to a flanged hub on the front diff, (maybe that is Bravada only) remove them there. I think the outer axle stub would need to be retained though, the torque on the end of the axle preloads the front wheel bearings.
| 4x4 12 bolt rear end same as 2wd rear end??? | Ed ke6bnl | Transmission - Rearend | 2 | 05-24-2008 02:25 PM |
| Converting an '83 Scottsdale 2Wheel Drive to 4x4 | ChevyJim | Suspension - Brakes - Steering | 9 | 03-25-2007 07:55 PM |
| 2wd to 4x4 700r4 | QUINTANA64 | Transmission - Rearend | 7 | 04-05-2006 05:20 PM |
| Launching a 4X4. | Rubberman2003 | Hotrodders' Lounge | 6 | 03-02-2004 03:06 PM |
| Converting 2wd 700r4 to 4x4 | dboriack | Transmission - Rearend | 2 | 02-12-2004 06:09 AM |
